Aller au contenu principal
Polaroid I-2 Front Cover Replacement
Ce dont vous avez besoin
  1. Polaroid I-2 Front Cover Replacement, Safety information: étape 1, image 1 de 3 Polaroid I-2 Front Cover Replacement, Safety information: étape 1, image 2 de 3 Polaroid I-2 Front Cover Replacement, Safety information: étape 1, image 3 de 3
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Front Cover Replacement, Open the film door: étape 2, image 1 de 2 Polaroid I-2 Front Cover Replacement, Open the film door: étape 2, image 2 de 2
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Front Cover Replacement, Insert a blocker: étape 3, image 1 de 3 Polaroid I-2 Front Cover Replacement, Insert a blocker: étape 3, image 2 de 3 Polaroid I-2 Front Cover Replacement, Insert a blocker: étape 3, image 3 de 3
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Front Cover Replacement, Flip the camera over: étape 4, image 1 de 3 Polaroid I-2 Front Cover Replacement, Flip the camera over: étape 4, image 2 de 3 Polaroid I-2 Front Cover Replacement, Flip the camera over: étape 4, image 3 de 3
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Front Cover Replacement, Unfasten the bottom cover: étape 5, image 1 de 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Front Cover Replacement, Unclip the bottom cover: étape 6, image 1 de 3 Polaroid I-2 Front Cover Replacement, Unclip the bottom cover: étape 6, image 2 de 3 Polaroid I-2 Front Cover Replacement, Unclip the bottom cover: étape 6, image 3 de 3
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Front Cover Replacement: étape 7, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 7, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 7, image 3 de 3
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Front Cover Replacement: étape 8, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 8, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 8, image 3 de 3
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Front Cover Replacement: étape 9, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 9, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 9, image 3 de 3
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Front Cover Replacement, Remove the bottom cover: étape 10, image 1 de 3 Polaroid I-2 Front Cover Replacement, Remove the bottom cover: étape 10, image 2 de 3 Polaroid I-2 Front Cover Replacement, Remove the bottom cover: étape 10, image 3 de 3
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 Front Cover Replacement, Disconnect the film door: étape 11, image 1 de 3 Polaroid I-2 Front Cover Replacement, Disconnect the film door: étape 11, image 2 de 3 Polaroid I-2 Front Cover Replacement, Disconnect the film door: étape 11, image 3 de 3
    • Insert the flat end of a spudger between the film door's left hinge and the frame.
    • Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
    • Pull the film door towards the front of the camera to completely disconnect its left hinge.
  12. Polaroid I-2 Front Cover Replacement: étape 12, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 12, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 12, image 3 de 3
    • Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
    • Remove the film door.
    • At this point, you can remove the cloth blocker from under the print roller.
    • During reassembly, hook the left hinge on its post and push the right hinge over its post until it snaps into place.
  13. Polaroid I-2 Front Cover Replacement, Unfasten the back cover: étape 13, image 1 de 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
  14. Polaroid I-2 Front Cover Replacement, Unclip the back cover: étape 14, image 1 de 3 Polaroid I-2 Front Cover Replacement, Unclip the back cover: étape 14, image 2 de 3 Polaroid I-2 Front Cover Replacement, Unclip the back cover: étape 14, image 3 de 3
    • There are two alignment pegs along the bottom edge of the back cover.
    • Insert a spudger between the frame and the alignment hole on the back cover.
    • Twist the spudger to lift the back cover off of the alignment peg.
    • Repeat for the second alignment peg.
  15. Polaroid I-2 Front Cover Replacement, Disassembly information: étape 15, image 1 de 3 Polaroid I-2 Front Cover Replacement, Disassembly information: étape 15, image 2 de 3 Polaroid I-2 Front Cover Replacement, Disassembly information: étape 15, image 3 de 3
    • There are eight large clips that secure the back cover. The next four steps show how to release them.
    • These clips are very strong and require significant force to release.
    • The procedure to release the clips is tricky and will require time and patience to perform correctly.
  16. Polaroid I-2 Front Cover Replacement, Insert an opening pick: étape 16, image 1 de 3 Polaroid I-2 Front Cover Replacement, Insert an opening pick: étape 16, image 2 de 3 Polaroid I-2 Front Cover Replacement, Insert an opening pick: étape 16, image 3 de 3
    • Releasing the clips requires getting a tool between the covered "thin" edge of the front cover and the clips themselves.
    • Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
    • Push the pick up to get it above the overhanging lip in the back cover.
    • You'll see the plastic warp a little. This is normal.
    • While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
    • The pick can slip out easily, so this may take a few tries.
  17. Polaroid I-2 Front Cover Replacement: étape 17, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 17, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 17, image 3 de 3
    • While pushing the pick downward, slide it all the way up the right edge to release the clips.
    • Keep the pick as upright as possible while sliding to avoid hitting the clips.
    • The plastic in the lip of the back cover will warp. This is normal.
    • Leave the pick at the top corner before continuing to prevent the clips from resecuring.
  18. Polaroid I-2 Front Cover Replacement: étape 18, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 18, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 18, image 3 de 3
    • Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
    • While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
  19. Polaroid I-2 Front Cover Replacement: étape 19, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 19, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 19, image 3 de 3
    • While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
  20. Polaroid I-2 Front Cover Replacement, Reposition the back cover: étape 20, image 1 de 3 Polaroid I-2 Front Cover Replacement, Reposition the back cover: étape 20, image 2 de 3 Polaroid I-2 Front Cover Replacement, Reposition the back cover: étape 20, image 3 de 3
    • Don't try to pull the back cover off just yet, as it's still connected by a cable.
    • At this point, the back cover should feel loose. If any parts still feel connected, repeat the last four steps until all the clips release.
    • Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
    • During reassembly, make sure the the flex cable isn't caught between the covers before re‑engaging the clips.
  21. Polaroid I-2 Front Cover Replacement, Remove the tape: étape 21, image 1 de 3 Polaroid I-2 Front Cover Replacement, Remove the tape: étape 21, image 2 de 3 Polaroid I-2 Front Cover Replacement, Remove the tape: étape 21, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
    • Set the tape aside. You'll reuse it during reassembly.
  22. Polaroid I-2 Front Cover Replacement, Disconnect the control board: étape 22, image 1 de 2 Polaroid I-2 Front Cover Replacement, Disconnect the control board: étape 22, image 2 de 2
    • Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
  23. Polaroid I-2 Front Cover Replacement: étape 23, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 23, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 23, image 3 de 3
    • Use tweezers to pull the interconnect cable out of its slot in the control board.
  24. Polaroid I-2 Front Cover Replacement, Unfasten the top cover: étape 24, image 1 de 3 Polaroid I-2 Front Cover Replacement, Unfasten the top cover: étape 24, image 2 de 3 Polaroid I-2 Front Cover Replacement, Unfasten the top cover: étape 24, image 3 de 3
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the top cover.
  25. Polaroid I-2 Front Cover Replacement, Unclip the top cover: étape 25, image 1 de 2 Polaroid I-2 Front Cover Replacement, Unclip the top cover: étape 25, image 2 de 2
    • The next six steps demonstrate how to release the top cover's clips. These clips can re-engage easily, so you may need to repeat certain steps to release all of the clips.
    • Angle an opening pick upward and insert in the gap at the top right corner of the top cover and front cover, next to the flash.
  26. Polaroid I-2 Front Cover Replacement: étape 26, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 26, image 2 de 2
    • Leave the pick in the gap before continuing to prevent the clips from re‑engaging.
  27. Polaroid I-2 Front Cover Replacement: étape 27, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 27, image 2 de 2
    • Angle a second opening pick upward and insert in the gap at the top left corner of the top cover and front cover.
  28. Polaroid I-2 Front Cover Replacement: étape 28, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 28, image 2 de 2
    • Leave the pick in the gap before continuing to prevent the clips from re-engaging.
  29. Polaroid I-2 Front Cover Replacement: étape 29, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 29, image 2 de 2
    • Insert the flat end of a spudger between the frame and the top cover's left external clip, above the viewfinder.
    • Twist the spudger to release the clip.
    • If one of the opening picks fall out, don't worry! Continue with the guide as normal.
  30. Polaroid I-2 Front Cover Replacement: étape 30, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 30, image 2 de 2
    • Insert the tip of an opening pick between the frame and the top cover's right external clip.
    • Pry up to release the clip.
  31. Polaroid I-2 Front Cover Replacement, Remove the lens cap: étape 31, image 1 de 1
    • Pull the lens cap off and remove it.
  32. Polaroid I-2 Front Cover Replacement, Remove the top cover: étape 32, image 1 de 2 Polaroid I-2 Front Cover Replacement, Remove the top cover: étape 32, image 2 de 2
    • Lift the top cover off the camera and remove it.
    • During reassembly, push the top cover onto the frame until the clips re-engage.
  33. Polaroid I-2 Front Cover Replacement, Unfasten the front cover: étape 33, image 1 de 2 Polaroid I-2 Front Cover Replacement, Unfasten the front cover: étape 33, image 2 de 2
    • Use a Phillips screwdriver to remove the four screws securing the front cover:
    • Two 5.9 mm-long screws along the back edge of the front cover
    • Flip your camera over.
    • Two 3.9 mm-long screws under the front of the camera
  34. Polaroid I-2 Front Cover Replacement, Unclip the front cover: étape 34, image 1 de 2 Polaroid I-2 Front Cover Replacement, Unclip the front cover: étape 34, image 2 de 2
    • The clips that secure the front cover are tricky to release. During the removal procedure, you may have to wiggle and bend the plastic to get the clips to release properly.
    • Pull the front cover away from the lens to release the clips along the front edge and slide the viewfinder out of its cutout.
    • You'll hear a "click" and the front cover will be able to move freely.
    • During reassembly, align the viewfinder cutout over the viewfinder lens before pressing the front cover into place and re-engaging the clips.
  35. Polaroid I-2 Front Cover Replacement, Remove the lidar sensor bracket: étape 35, image 1 de 3 Polaroid I-2 Front Cover Replacement, Remove the lidar sensor bracket: étape 35, image 2 de 3 Polaroid I-2 Front Cover Replacement, Remove the lidar sensor bracket: étape 35, image 3 de 3
    J'achète
    • The lidar sensor bracket is secured with two alignment pegs that fit into cutouts on the bracket.
    • Use tweezers, or your fingers, to push the lidar sensor bracket toward the lidar sensor and off its alignment pegs.
    • Remove the lidar sensor bracket.
  36. Polaroid I-2 Front Cover Replacement, Remove the front cover: étape 36, image 1 de 2 Polaroid I-2 Front Cover Replacement, Remove the front cover: étape 36, image 2 de 2
    • Lift the rear of the front cover while pulling the entire cover toward the front of the camera to separate it from its lip under the lens.
    • If you're having trouble, rock the cover side-to-side while pulling.
  37. Polaroid I-2 Front Cover Replacement: étape 37, image 1 de 3 Polaroid I-2 Front Cover Replacement: étape 37, image 2 de 3 Polaroid I-2 Front Cover Replacement: étape 37, image 3 de 3
    • Lift the front of the cover over the lens.
    • Slide the front cover toward the rear of the camera until the back edge clears the viewfinder.
  38. Polaroid I-2 Front Cover Replacement: étape 38, image 1 de 2 Polaroid I-2 Front Cover Replacement: étape 38, image 2 de 2
    • Remove the front cover.
    • If you're disassembling further, put the lens cover back on to prevent scratching the lens.
    • At this point, the metal film door lever and spring are at risk of falling out. If they do, follow this guide to reinstall them.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
126 582 Réputation
592 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
138 membres
17 678 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 141
