Full Case
1 Réponse Indice de 1 |
hard drive en panne |
2 Réponses Indice de 1 |
Why is my external hard drive making this weird noise & not showing up |
3 Réponses Indice de 3 |
Can HDDs operate upside down? |
1 Réponse Indice de 2 |
Hdd is not getting detected |
Outils
Voici quelques outils couramment utilisés pour travailler sur cet appareil. Vous ne devriez pas avoir besoin de tous les outils pour chaque procédure.
Background and Identification
A hard disk drive (HDD), hard disk, hard drive, or fixed disk is an electromechanical data storage device that uses magnetic storage to store and recall digital data using rapidly rotating plates coated with magnetic material. The plates are paired with magnetic hears that are usually arranged on a moving actuator arm and are designed to read and write data to the plate surfaces. Stored data is accessed in a random-accessed manner, meaning that blocks of data can be stored and recalled in any order. Hard drives retain stored data even when powered off, making them a type of non-volatile storage.
Hard drives were introduced by IBM in 1956 as the dominant secondary storage device for computers. Hard drives became the main storage devices for servers and personal computers, as well, though personal computers produced en masse, like tablets and cell phones, rely on flash products. Historically, over 224 companies have produced hard drives.
Solid-state drives (SSDs) are also used for data storage but feature higher data-transfer rates, better reliability, higher areal storage, and lower latency and access times.
Hard drives are often characterized by capacity and performance. Capacity is generally specified with unit prefixes corresponding to powers of 1,000. For instance, a 1-terabyte (TB) hard drive has a capacity of 1,000 gigabytes (GB, where 1 gigabyte is equal to 1 billion bytes). Performance is specified by the time required to move the device’s heads to a track, or the average access time, and the data transmission rate.
