Humane AI Pin Chip ID
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Background Information
Initially revealed in May 2023 and officially announced in July 2023, the Humane AI Pin is an AI assistant meant to replace traditional smartphones.
The AI Pin's notable lack of an LCD sets it apart from smartphones. Instead, it can be operated by voice commands, touch gestures for quick actions, or the Laser Beam Scanning Projection System.
The Humane AI Pin is available in three different finishes.
- Eclipse: Super Matte Black Anodized finish w/ Black Touchpad for $700
- Equinox: Polished Silver Finish w/ Black Touchpad for $800
- Lunar: Polished Silver Finish w/ White Touchpad $800
News
Technical Specifications
Summary
- Display: Laser Ink Display
- Processor: Octa-core Qualcomm Snapdragon
- Camera: 12 MP Wide Camera
- Charging: Wireless Power Charging Method
- Operating System: Cosos
- Cellular: 4G LTE
- Storage: 32 GB eMMC
- Clasps:
- Latch
- Battery Booster
- Clip
Colors/Housing Finishes
- Finishes/Touchpad Colors
Dimensions
- AI Pin Dimensions:
- Length: 1.87" (47.5 mm)
- Width: 1.75" (44.5 mm)
- Depth: 0.59" (14.98 mm) @ thickest point, 0.32" (8.25 mm) @ thinnest point
- Weight: 34.2 g
- Battery Booster Dimensions:
- Length: 1.86" (47.16 mm)
- Width: 1.78" (45.2 mm)
- Depth: 0.32" (8.25 mm)
- Weight: 20.5 g
Display
- Type: Laser Ink Display
- Technology: Laser Beam Scanning Projection System
- Resolution: 720p Resolution
- Operating Distance: 7.87" (20 cm) - 15.75" (40 cm)
- Field-of-View: 18.2° wide, 13.3° tall, 22.4° diagonal (7 cm x 9.6 cm at 30 cm distance)
Laser
- Diode: Custom-Color Single-Diode Laser
- Safety Classification: Class 2 per IEC60825-2014
- Peak Wavelength: 498 nm
- Projection Divergence half-angles: 18.2° x 13.3°
- Projection divergence full FOV: 18.2° x 13.3°
- Projection divergence half angles: 9.1° x 6.7°
- Variable pulse duration: 10 ns - 20 µs
- Peak Emissions: 25 mW
Audio
- Output: Built-in Speaker
- Input: Dual Microphone Array
- Audio Codec: AAC
- Audio Calling: Voice over LTE (VoLTE), 3G
What's in the Box
- 2 x Battery Boosters
- 1 x USB-C Adapter and Cable
- 1 x Charge Pad
- 1 x Charge Case
