JUSTFOG Q16 Pro Teardown
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Outils
Voici quelques outils couramment utilisés pour travailler sur cet appareil. Vous ne devriez pas avoir besoin de tous les outils pour chaque procédure.
Background and Identification
The Justfog Q16 Pro is a popular electronic cigarette (e-cigarette) that is known for its compact and portable design, as well as its ease of use and maintenance. The device utilizes a clearomizer, which is a type of e-liquid container, and a battery to vaporize e-liquid, which is then inhaled by the user.
The device has a built-in 900mAh battery and a 1.9ml e-liquid capacity tank. The 900mAh battery is known for its long battery life, which allows for extended use between charges. The device also has an easy-to-use, one-button operation, making it a great choice for both new and experienced vapers.
The device has a compact and lightweight design, which makes it easy to carry around and use on the go. It also features a childproof and leak-proof design, which adds to its safety and ease of use.
The device is designed for mouth-to-lung (MTL) vaping, which is a type of vaping that closely mimics the sensation of smoking a traditional cigarette. MTL vaping is popular among new vapers and experienced vapers who prefer a tighter draw and a more satisfying hit.
Specifications
Height: 70.4 mm
Width: 25.2 mm
Depth: 16.5 mm
Weight: 38g
Voltage: 3.5 - 3.8 - 4.1 - 4.4
Battery Size: 900mAh
Colors: Blue, Pink, Silver, Black
