Moteur pas à pas
1 Réponse Indice de 0 |
Microtek Scanmaker 8700 repair |
1 Réponse Indice de -1 |
Scanner stops locks-up right before starting a scan. |
Outils
Voici quelques outils couramment utilisés pour travailler sur cet appareil. Vous ne devriez pas avoir besoin de tous les outils pour chaque procédure.
Background
Released in the early 2000's, the Microtek Scanmaker was made to be everything that either a small business or independent designer needed in a digital imaging device.
Identification
The Microtek Scanmaker 5900 is easily identifiable as a scanner due to its easy open lid that reveals a glass surface for placing your pictures and documents on it.
It can further be identified by the fact that it says Microtek ScanMaker 5900 on the lid of the device. Refer to the manufacturers website for further details.
Technical Specs
Buttons
- 7 Smart-touch buttons + 1 Power on/off button: Scan, Copy, Email, OCR, Scan-to-Web, Cancel , Custom and Power on/off
Platform
- Windows & Macintosh
Interface Type
- USB 2.0
Scan Area
- 8.5" x 11.7"
Max. Interpolated Resolution
- 65535 x 65535 dpi (PC)
- 32768 x 32768 dpi (Mac)
Color Passes
- Single pass
Image Sensor
- Sigma Six CCD Technology (Dual 10,600-element stacked CCDs)
Optical Resolution
- 4800 x 2400 dpi
Bit Depth
- True 48-bit input and output (trillions of colors)
Included Accessory
- Integrated 4" x 5" Transparency Adapter with FilmView
Optional Accessory
- 50-page automatic document feeder
PC System Requirements
- 64MB RAM (128MB recommended); Pentium PC or later
- USB: USB port & Windows 98/2000/Me/XP
Mac System Requirements
- 64MB RAM (128MB recommended); iMac/G3/G4
- USB: Built-in USB port & Mac OS 9.0 ~ 9.x or OS X (classic mode)
Voltage
- 110V / 220V
Scanner Weight
- 5.7 lbs / 2.6 kg
Scanner Dimensions
- 19.0" x 11.5" x 2.9" (LxWxH)
- 483mm x 294mm x 78mm (LxWxH)
