7 Réponses Indice de 1 |
mon afficheur ne marche plus! |
11 Réponses Indice de 14 |
Not charging at all. |
1 Réponse Indice de 2 |
Why my mi band showing power full but not turning on without changer |
1 Réponse Indice de 4 |
Mi-Band 5 got water damage and broken screen |
Background and Identification
The Xiaomi Mi Band is a wearable fitness tracker, released by Chinese electronics company Xiaomi Corporation in 2014. It can be worn around the wrist, ankle, or neck. The device can track physical activity and sleep, can unlock your Android smartphone, and is water resistant. The wristband is available in black, blue, green, lime green, orange, and pink.
The second iteration of the Xiaomi Mi Band, the Xiaomi Mi Band 1S (also known as Mi Band Pulse) was released in 2015. The main difference between the two devices is the addition of a heart rate sensor on the Mi Band 1S. Due to the heart rate sensor, the battery life of the Xiaomi Mi Band 1S does not last as long as its predecessor.
The Xiaomi Mi Band 1S was followed by the Xiaomi Mi Band 2 in 2016, the Xiaomi Mi Band 3 in 2018, the Xiaomi Mi Band 4 in 2019, and the Xiaomi Mi Band 5 in 2020.
Specifications
Mi Band Sensor
Height: 36mm
Width: 14mm
Depth: 9mm
Weight: 5g
Surface Material: 100% aluminum alloy
Indicator Lights: Blue, green, red, orange
Body Casing Material: Polycarbonate
Water/dust Resistance: IP67
Bluetooth Version: 4.0
Battery
Depth: 8mm
Battery Capacity: 41 mAh
Battery Type: Lithium polymer
Input Current: 25 mA(TYP)
Input Voltage: DC 5.0 V
Band
Full Length: 225m
Adjustable Length: 157mm to 205mm
Material: Dow Corning TPSiV
Compatibility
Compatible with Mi 4, Mi 3, Redmi Note 4G, or any device with Android 4.4 and above. Compatible with iPhone models 4s and above that run on iOS 7.0 and above.
Mi Band's phone unlocking feature requires smartphones with MIUI or Android 5.0 and above.
Additional Information
Wikipedia: Xiaomi Mi Band
Product Page: Xiaomi Mi Band
Amazon: Xiaomi Mi Band
