Aller au contenu principal
Acer Aspire E1-470P-6659 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-470P-6659 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 2, image 1 de 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 3, image 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 3, image 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 3, image 3 de 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 4, image 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 4, image 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 4, image 3 de 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: étape 5, image 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: étape 5, image 2 de 2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 6, image 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 6, image 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 6, image 3 de 3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 7, image 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 7, image 2 de 2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 8, image 1 de 1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 10, image 1 de 1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: étape 11, image 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: étape 11, image 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: étape 11, image 3 de 3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Motherboard Replacement: étape 12, image 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement: étape 12, image 2 de 2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
Faith Lobaton
Membre depuis le 10/22/18
497 Réputation
3 tutoriels rédigés
Équipe
UC Davis, Team S4-G5, Lore Fall 2018 Membre de l'équipe UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 911
