Aller au contenu principal
Acer Nitro 5 AN515-53-52FA Battery Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: étape 1, image 1 de 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 2, image 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 2, image 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 3, image 2 de 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 5, image 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 5, image 2 de 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 6, image 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: étape 6, image 2 de 2
    • Lift the battery up and out of the laptop.
Alfredo Prieto
Membre depuis le 09/01/22
827 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-3, Pee Fall 2022 Membre de l'équipe Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 membres
5 tutoriels rédigés
2 commentaires
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Réponse
Can I use a Jimmy instead of the opening picks?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 99
Total : 995
