Aller au contenu principal
The Acer Aspire R5-571T-59DC is a convertible laptop-to-tablet PC released June 2016.
8 questions Voir tout
Replacing power port - plug doesn't fit in tightly
The plug does not fit snugly into the port and it is hard to get it to retain a connection. A new adapter is loose as well. From research it looks like to replace it on this model requires soldering? Is there anything else I can do short of paying someone to solder in a new one? Thanks.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
@onyxeyez you are correct that the DC-IN socket is directly soldered to the motherboard. You will have to get it soldered and it might help and be less expensive, if you remove the motherboard and get it soldered by someone local.
Indice 4
1 commentaire:
Thank you, If I need to get it replaced I will do that. I can take it apart fine, it is the soldering I can't.
par
Ajouter une réponse
Onyx sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 17
Total : 385
