Why won't my gas fireplace light when I turn on the switch? Pilot on.
My gas fireplace has a wall switch to turn it on but it doesn’t work. I see the pilot light burning and the gas valve to the fireplace is on.
Best left to a professional but you might be able to fix simple things. The pilot light should have a small metal rod or two beside it with the flame heating them up. This is a safety system designed to keep the fireplace from lighting if the pilot light is extinguished. If the rod is too cold the fireplace won’t turn on the gas valve to light. To test where the problem might lie, use a long-nosed butane grill lighter to add additional heat to those metal rods to see if the fireplace will light. Be ready to step back if it lights the fireplace to avoid hairless arms. You may need to hold the flame of the grill lighter on the metal rod for 30-45 seconds (with the switch turned on) to heat it up.
If the fireplace starts then it’s likely 1. the pilot light needs to be turned up a little. check the gas valve on the internet to see how and/or 2. the thin tube feeding gas to the pilot may need cleaning . they commonly get spider webs inside them (if you remove it turn OFF THE GAS and don’t kink the tube reinstalling it.
As said before, this is something you should leave to a professional, but here is my read on it...
There are actually two systems that generate electrical energy from the pilot light. Both are usually located right next to the pilot burner, on opposite sides of it:
One other thing that many people forget is to also check the actual On-Off switch, as these can go bad. Check it out for continuity, as this may also cause the same symptoms.
On the Heat & Glo all you need to do is tap on the gas valve gently with a hammer or rubber mallet. Turn it on so the pilot is lit. Tap on the round flat part of the valve that is facing you, and voila, the burner will light. Not sure why that works. If anyone knows why, please let me know.
Dernières 24 heures : 13
7 derniers jours : 111
30 derniers jours : 456
Total : 29,235
1 commentaire
my fireplace does the same thing and my husband's answer is to bang on the front of it with his fist
honestly that scares the crap out of me !! I am going to try the answers shown here, if the don't work I will call a professional !!
Thanks for help that doesnt need to involve a fist !!
par Kelly Gardner
