Le téléphone est mouillé d'eau
Mon téléphone est tombé dans l'eau et ne marche plus , que puis je faire pour le reparer
@mohamed8628241 For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for this phone, use something like this guide as well as this one for the charging board, to help you disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields off these boards. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc, as well as all flex cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol (or higher concentration) and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the parts you cleaned,to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. In the case of your phone, I would also change the charging board as well as the flex cable from the charging board to tthe main board
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
Translation
Pour l'instant, vous devez cesser d'essayer de charger, de synchroniser ou d'utiliser votre téléphone. Cela risque d'aggraver une situation déjà difficile. Cela risque d'endommager davantage votre téléphone.
La première chose à faire est de démonter votre téléphone. Puisque iFixit n'a pas encore de guide pour ce téléphone, utilisez quelque chose comme ce guide ainsi que ce guide pour la carte de charge, pour vous aider à démonter votre téléphone. Retirez la carte principale et la carte de chargement. Vous devrez retirer tous les écrans EMI de ces cartes. Si vous ne les retirez pas, vous ne nettoyez pas la carte.
Examinez attentivement tous les composants et les connecteurs. Évaluez vraiment les dommages. Recherchez la corrosion majeure, évaluez les broches des connecteurs, etc., ainsi que toutes les extrémités des câbles flexibles. Une fois que vous avez nettoyé toute contamination grossière, utilisez de l'alcool isopropylique à 90 % ou plus (ou une concentration plus élevée) et nettoyez encore vos pièces. Pour un bon nettoyage, utilisez le ce guide Il a été écrit pour un Apple iPhone 3G mais toutes les étapes sont pertinentes pour votre téléphone également. Je ne saurais trop insister sur l'importance d'un bon nettoyage, alors recommencez plusieurs fois en remplaçant l'alcool après chaque nettoyage.
N'utilisez pas d'air comprimé pour le nettoyage, car cela peut entraîner du liquide et des particules de corrosion dans des zones qui causeront des problèmes plus tard. Il n'est pas nécessaire de laisser sécher les pièces nettoyées pendant une journée. L'alcool isopropylique à forte concentration s'évaporera rapidement et dissipera l'eau.
Ce qui importe ici, c'est le nettoyage. Le mieux est évidemment de le faire nettoyer aux ultrasons. N'oubliez pas de remplacer la batterie. Il s'agit d'une obligation et non d'une option. Elle tombera en panne si vous ne vous en occupez pas maintenant. Dans le cas de votre téléphone, je remplacerais également la carte de chargement ainsi que le câble flexible reliant la carte de chargement à la carte principale.
Ensuite, remontez votre téléphone et réévaluez-le. Tant que vous n'avez pas nettoyé votre carte et remplacé la batterie, tout n'est que supposition. Gardez à l'esprit que les dégâts causés par l'eau sont les plus difficiles à diagnostiquer et à réparer.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 25
