Pourquoi mon ordinateur de cette marque ne s'allume plus?
Mon pc ne s'allume plus du tout
@melegnaamarc Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure the connectors are not bend etc. After that, check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see with your question. That way we can see what you see.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
It is also possible (but unlikely) that this is a bad RAM module. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Translation
@melegnaamarc Commence par les choses les plus simples. Coupe l'alimentation de l'ordinateur en débranchant le cordon d'alimentation de ton ordinateur. Déconnecte tous les périphériques externes de l'ordinateur. Retire la batterie Maintenant, maintiens le bouton d'alimentation enfoncé pendant environ 30sec-1min. Remets l'adaptateur secteur en place et regarde si ton ordinateur montre un signe de vie.
Ensuite, tu dois vérifier ton alimentation. Assure-toi que la tension est correcte. Vérifie que les connecteurs ne sont pas pliés, etc. Ensuite, vérifie la prise de courant continu de ton ordinateur portable. Assure-toi qu'il n'y a pas de corrosion, de débris, etc. qui l'empêchent de fonctionner. Nettoie-la de tout débris, etc., utilise quelques bouffées d'air pour la nettoyer.
Si rien de tout cela ne fonctionne, procure-toi un ampèremètre et vérifie si ton ordinateur portable tire un quelconque ampérage du chargeur. Après cela, tu dois vérifier si ta carte mère est alimentée. Pour cela, tu dois bien sûr l'ouvrir. Publie quelques bonnes photos de ce que tu vois avec ta question. De cette façon, nous pourrons voir ce que tu vois.
Bien sûr, il faut aussi envisager de remplacer la batterie. Une batterie épuisée ne peut plus être chargée. Cependant, elle ne devrait pas empêcher ton ordinateur de s'allumer, s'il est branché sur l'adaptateur secteur.
Il est également possible (mais peu probable) qu'il s'agisse d'un mauvais module de mémoire vive. Retire donc la mémoire vive, nettoie les contacts avec une gomme à crayon. Fais-le délicatement pour ne pas détruire le module. Remets-le en place et redémarre. Si tu as plus d'un module, enlève-le et laisse-en un seul branché.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 27
