Que faire quand l'écran tactile de mon redmi ne fonct plus à cause de
Mon redmi est tombé dans l'eau et l'écran tactile ne répond plus
@albertenst89260 you will need to treat this just like you would any other water damaged device.
For now you need to stop continuing to try to charge, sync or otherwise using your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using Mi 9 these guides . You must remove all EMI shields of your boards . If you do not remove those, you might as well not do anything. After you removed those, clean the boards, connectors and all with +90% isopropyl alcohol. Follow this guide. It was written for an Apple iPhone 3G and all the points are still pertinent to your phone. While you clean your boards, check for any obvious damage, like burned or missing components etc. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. When they are properly cleaned, replace the battery.
All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad display assembly (which includes the touchscreen) and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@albertenst89260 tu devras traiter ce problème comme n'importe quel autre appareil endommagé par l'eau.
Pour l'instant, tu dois arrêter de continuer à essayer de charger, de synchroniser ou d'utiliser ton téléphone d'une autre manière. Cela risque d'aggraver une situation déjà difficile et d'endommager encore plus ton téléphone.
La prochaine chose à faire est de le nettoyer. Démonte ton téléphone à l'aide de Mi 9 ces guides. Tu dois retirer tous les écrans EMI de tes cartes. Si tu ne les enlèves pas, autant ne rien faire. Après les avoir enlevés, nettoie les cartes, les connecteurs et tout le reste avec de l'alcool isopropylique à +90%. Suis le ce guide. Il a été écrit pour un Apple iPhone 3G et tous les points sont encore pertinents pour ton téléphone. Pendant que tu nettoies tes cartes, vérifie qu'il n'y a pas de dommages évidents, comme des composants brûlés ou manquants, etc. Je ne saurais trop insister sur l'importance d'un bon nettoyage, alors fais-le encore et encore en remplaçant l'alcool après chaque nettoyage. Lorsqu'elles sont correctement nettoyées, remplace la batterie.
Toutes ces étapes ont pour but d'éviter une défaillance tardive causée par la corrosion. Le mieux serait de la nettoyer avec un nettoyeur à ultrasons, mais si tu n'as pas accès à un tel appareil, ceci t'aidera au moins. Une fois que tout cela est fait, réassemble ton téléphone et réévalue-le. Tant qu'il n'est pas nettoyé, tout ne sera qu'une supposition. Il est possible que tu aies un mauvais assemblage d'écran (qui comprend l'écran tactile) et le fait de remplacer l'assemblage d'écran peut régler le problème. Même avec tout cela, les dégâts d'eau n'ont qu'une petite chance d'être entièrement réparés, mais au moins tu peux essayer.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 14
