Aller au contenu principal
2004 Lexus 330 RX Battery Replacement
Ce dont vous avez besoin
  1. 2004 Lexus 330 RX Battery Replacement, Battery: étape 1, image 1 de 3 2004 Lexus 330 RX Battery Replacement, Battery: étape 1, image 2 de 3 2004 Lexus 330 RX Battery Replacement, Battery: étape 1, image 3 de 3
    • Pull up the lever underneath the steering wheel to pop up the hood.
    • Unlatch the hood.
    • The battery should be located on the lower right side of engine.
  2. 2004 Lexus 330 RX Battery Replacement: étape 2, image 1 de 3 2004 Lexus 330 RX Battery Replacement: étape 2, image 2 de 3 2004 Lexus 330 RX Battery Replacement: étape 2, image 3 de 3
    • Use a wrench with a 10 mm socket to remove the bolts of the bracket.
    • Repeat the step above for the second bolt.
  3. 2004 Lexus 330 RX Battery Replacement: étape 3, image 1 de 3 2004 Lexus 330 RX Battery Replacement: étape 3, image 2 de 3 2004 Lexus 330 RX Battery Replacement: étape 3, image 3 de 3
    • Remove the metal rod on top of the battery.
    • The second and third pictures were taken without the battery for a better view of the rod.
  4. 2004 Lexus 330 RX Battery Replacement: étape 4, image 1 de 3 2004 Lexus 330 RX Battery Replacement: étape 4, image 2 de 3 2004 Lexus 330 RX Battery Replacement: étape 4, image 3 de 3
    • Remove the bolts on the clamps with a 10 mm socket.
    • Repeat the process on the second terminal of the battery.
  5. 2004 Lexus 330 RX Battery Replacement: étape 5, image 1 de 3 2004 Lexus 330 RX Battery Replacement: étape 5, image 2 de 3 2004 Lexus 330 RX Battery Replacement: étape 5, image 3 de 3
    • Carefully remove the clamps from the terminal.
    • Sometimes clamps are stuck in place due to corrosion or battery leak. Use caution while removing it.
  6. 2004 Lexus 330 RX Battery Replacement: étape 6, image 1 de 2 2004 Lexus 330 RX Battery Replacement: étape 6, image 2 de 2
    • Carefully remove the battery from the engine.
    • Do not tilt the battery while removing it.
  7. 2004 Lexus 330 RX Battery Replacement: étape 7, image 1 de 2 2004 Lexus 330 RX Battery Replacement: étape 7, image 2 de 2
    • Insert the new battery in the engine.
    • Place the metal rod back in place.
  8. 2004 Lexus 330 RX Battery Replacement: étape 8, image 1 de 2 2004 Lexus 330 RX Battery Replacement: étape 8, image 2 de 2
    • Place the bracket back on top of the battery.
    • Use a wrench with a 10 mm socket to secure the bolts of the bracket.
    • Repeat the above step for the second bolt.
  9. 2004 Lexus 330 RX Battery Replacement: étape 9, image 1 de 3 2004 Lexus 330 RX Battery Replacement: étape 9, image 2 de 3 2004 Lexus 330 RX Battery Replacement: étape 9, image 3 de 3
    • Put the terminal back on.
    • Put the bolts on the clamps back on with a 10 mm socket.
    • Repeat the previous step for the second bolt.
You have successfully changed the battery of Lexus 330 RX 200. Good Job!
4 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 75
Total : 3,090
