Aller au contenu principal
2007-2013 BMW X5 E70 Cabin Air Filter Replacement
Ce dont vous avez besoin
  1. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 3 de 3
    • Pop and lift the hood by pulling the release lever below the driver's seat.
    • The plastic filter cover is located on the upper left corner of the engine bay.
  2. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 2, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 2, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 2, image 3 de 3
    • There are four plastic screws on the air filter cover.
    • Twist each of the plastic screws with the half inch screw driver a quarter turn counter-clockwise。
    • Mind the plastic hood support while removing the plastic cover toward the right hand side.
  3. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 3, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 3, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 3, image 3 de 3
    • Once plastic cover has been removed, cabin air filter cover will be exposed.
    • There are three 1/2" plastic bolts.
    • Unscrew each plastic bolt by turning a quarter turn counter clockwise.
  4. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 4, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 4, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 4, image 3 de 3
    • Remove the electronic plastic connector before removing air filter cover.
    • Remove the air filter cover from the vehicle.
  5. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 5, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 5, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 5, image 3 de 3
    • Once the filter cover has been removed two air cabin filters will be exposed.
    • Locate the plastic clips on each end of the filter holder
    • Depress the clips using your thumbs to remove the air filter.
  6. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 6, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 6, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 6, image 3 de 3
    • Pay attention to Air Flow indicator arrows when reinstalling the filters.
    • Clip the filters back into place one side at a time.
    • Repeat the process for the second filter.
  7. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 7, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 7, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 7, image 3 de 3
    • Reinstall the filter cover.
    • Re-connect the plastic electronic plug.
  8. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 8, image 1 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 8, image 2 de 3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: étape 8, image 3 de 3
    • Re-install the plastic cover.
    • Mind the hydraulic lift for the hood while re-installing plastic cover.
    • Clean dust off the cover for good measure.
To reassemble your device follow these instructions in reverse order.
6 autres ont terminé cette réparation.
Patrick Whitmire
Membre depuis le 04/28/17
227 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S4-G3, Cole Spring 2017 Membre de l'équipe UC Davis, Team S4-G3, Cole Spring 2017
UCD-COLE-S17S4G3
3 membres
1 tutoriel rédigé
Un commentaire
This is not a cabin filter lol
E70/E71 have an actual cabin filter under the glove box.
lifeoftech - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 55
30 derniers jours : 219
Total : 14,898
