Aller au contenu principal
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 2, image 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 2, image 2 de 2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 3, image 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 3, image 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 4, image 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 4, image 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 4, image 3 de 3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 5, image 1 de 1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 6, image 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 6, image 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 6, image 3 de 3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 7, image 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 7, image 2 de 2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 8, image 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: étape 8, image 2 de 2
    • Close trunk and admire your hard work!
Juan M Perez
Membre depuis le 10/05/21
190 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 11-99, Grodsky Fall 2021 Membre de l'équipe CSU Los Angeles, Team 11-99, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G99
1 membre
1 tutoriel rédigé
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 82
Total : 2,311
