Aller au contenu principal
2012-2018 Nissan Versa Note Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: étape 1, image 2 de 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 2, image 1 de 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 3, image 1 de 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 4, image 1 de 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 5, image 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 5, image 2 de 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 6, image 1 de 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 7, image 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 7, image 2 de 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 8, image 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 8, image 2 de 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 9, image 1 de 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 10, image 1 de 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: étape 10, image 2 de 2
    • Insert the connector into the bulb.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Chelsea Chineme
Membre depuis le 09/28/21
229 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 56
30 derniers jours : 284
Total : 12,562
