Aller au contenu principal
2021 Honda HR-V Rear Signal Light Bulb Replacement
Ce dont vous avez besoin
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: étape 1, image 1 de 1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 2, image 1 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 2, image 2 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 2, image 3 de 3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 3, image 1 de 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 3, image 2 de 2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 4, image 1 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 4, image 2 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 4, image 3 de 3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 5, image 1 de 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 5, image 2 de 2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 6, image 1 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 6, image 2 de 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: étape 6, image 3 de 3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Ligne d'arrivée
Guadalupe Guevara
Membre depuis le 10/26/22
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-8, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 2-8, Briggs Fall 2022
CSULA-BRIGGS-F22S2G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 41
Total : 1,144
