Aller au contenu principal
Acer Aspire 3003WLCi Internal Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire 3003WLCi Internal Fan Replacement, Battery: étape 1, image 1 de 1
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Internal Fan Replacement: étape 2, image 1 de 3 Acer Aspire 3003WLCi Internal Fan Replacement: étape 2, image 2 de 3 Acer Aspire 3003WLCi Internal Fan Replacement: étape 2, image 3 de 3
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Internal Fan Replacement: étape 3, image 1 de 2 Acer Aspire 3003WLCi Internal Fan Replacement: étape 3, image 2 de 2
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
  4. Acer Aspire 3003WLCi Internal Fan Replacement, Internal Fan: étape 4, image 1 de 1
    • The panel you will be removing to access the internal fan is located at the bottom of the laptop.
  5. Acer Aspire 3003WLCi Internal Fan Replacement: étape 5, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws on the panel.
    • The screws will not come out of the panel. This is intentional by the manufacturer.
  6. Acer Aspire 3003WLCi Internal Fan Replacement: étape 6, image 1 de 1
    • Lift and remove the panel.
    • If you have difficulty removing the panel, use a spudger to pry the panel open.
  7. Acer Aspire 3003WLCi Internal Fan Replacement: étape 7, image 1 de 3 Acer Aspire 3003WLCi Internal Fan Replacement: étape 7, image 2 de 3 Acer Aspire 3003WLCi Internal Fan Replacement: étape 7, image 3 de 3
    • The fan is in the upper right corner of the panel.
    • Using a Phillips #00 screwdriver, remove each of the four 2.5mm screws securing the fan to the laptop.
  8. Acer Aspire 3003WLCi Internal Fan Replacement: étape 8, image 1 de 2 Acer Aspire 3003WLCi Internal Fan Replacement: étape 8, image 2 de 2
    • Disconnect the fan power cable from the motherboard by pulling the cable up and out of the connector.
  9. Acer Aspire 3003WLCi Internal Fan Replacement: étape 9, image 1 de 2 Acer Aspire 3003WLCi Internal Fan Replacement: étape 9, image 2 de 2
    • Remove the fan by pulling it away from its surrounding copper.
    • The fan is secured on the other side of the copper by a piece of tape, so it may help to wiggle the fan multiple times to try and loosen the tape.
Tristin Viale
Membre depuis le 03/25/19
675 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S2G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 176
