Aller au contenu principal
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 2, image 1 de 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 2, image 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 3, image 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: étape 4, image 1 de 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: étape 4, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 5, image 1 de 1
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 6, image 1 de 1
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: étape 7, image 1 de 1
    • Lift the WiFi card on the left side to remove it.
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
Byeloth Hermanson
Membre depuis le 09/21/17
285 Réputation
2 tutoriels rédigés
Équipe
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 1,030
