Aller au contenu principal
Acer Aspire 5100 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Acer Aspire 5100 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: étape 2, image 1 de 3 Acer Aspire 5100 Keyboard Replacement: étape 2, image 2 de 3 Acer Aspire 5100 Keyboard Replacement: étape 2, image 3 de 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: étape 3, image 1 de 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
7 autres ont terminé cette réparation.
Brad Rollinson
Membre depuis le 09/29/10
1 113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
Un commentaire
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 13,289
