Aller au contenu principal
Acer Aspire 5100 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5100 RAM Replacement, RAM: étape 1, image 1 de 2 Acer Aspire 5100 RAM Replacement, RAM: étape 1, image 2 de 2
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: étape 2, image 1 de 3 Acer Aspire 5100 RAM Replacement: étape 2, image 2 de 3 Acer Aspire 5100 RAM Replacement: étape 2, image 3 de 3
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
7 autres ont terminé cette réparation.
Brad Rollinson
Membre depuis le 09/29/10
1 113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
Un commentaire
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 26
Total : 16,304
