Aller au contenu principal
Acer Aspire 5100 USB Add-on Card Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Acer Aspire 5100 USB Add-on Card Replacement, Cooling Fan: étape 1, image 1 de 1
    • Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
  2. Acer Aspire 5100 USB Add-on Card Replacement: étape 2, image 1 de 1
    • Lift up and remove the RAM and CPU cover.
  3. Acer Aspire 5100 USB Add-on Card Replacement: étape 3, image 1 de 1
    • Remove the two Phillips screws securing the fan.
    • Carefully disconnect the fan cable from the motherboard.
    • Lift up and remove the fan.
  4. Acer Aspire 5100 USB Add-on Card Replacement, Keyboard: étape 4, image 1 de 2 Acer Aspire 5100 USB Add-on Card Replacement, Keyboard: étape 4, image 2 de 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  5. Acer Aspire 5100 USB Add-on Card Replacement: étape 5, image 1 de 3 Acer Aspire 5100 USB Add-on Card Replacement: étape 5, image 2 de 3 Acer Aspire 5100 USB Add-on Card Replacement: étape 5, image 3 de 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  6. Acer Aspire 5100 USB Add-on Card Replacement: étape 6, image 1 de 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  7. Acer Aspire 5100 USB Add-on Card Replacement, Track Pad: étape 7, image 1 de 1
    • Remove the nine screws from the back edges of the laptop.
  8. Acer Aspire 5100 USB Add-on Card Replacement: étape 8, image 1 de 3 Acer Aspire 5100 USB Add-on Card Replacement: étape 8, image 2 de 3 Acer Aspire 5100 USB Add-on Card Replacement: étape 8, image 3 de 3
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  9. Acer Aspire 5100 USB Add-on Card Replacement: étape 9, image 1 de 2 Acer Aspire 5100 USB Add-on Card Replacement: étape 9, image 2 de 2
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  10. Acer Aspire 5100 USB Add-on Card Replacement: étape 10, image 1 de 1
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
  11. Acer Aspire 5100 USB Add-on Card Replacement, LCD Monitor: étape 11, image 1 de 1
    • Remove the two screws from each corner beneath the LCD screen.
  12. Acer Aspire 5100 USB Add-on Card Replacement: étape 12, image 1 de 2 Acer Aspire 5100 USB Add-on Card Replacement: étape 12, image 2 de 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  13. Acer Aspire 5100 USB Add-on Card Replacement: étape 13, image 1 de 2 Acer Aspire 5100 USB Add-on Card Replacement: étape 13, image 2 de 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  14. Acer Aspire 5100 USB Add-on Card Replacement: étape 14, image 1 de 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  15. Acer Aspire 5100 USB Add-on Card Replacement: étape 15, image 1 de 1
    • Lift up the monitor to detach it.
  16. Acer Aspire 5100 USB Add-on Card Replacement, Motherboard: étape 16, image 1 de 1
    • Remove the 15 screws from the motherboard.
    • There is normally only one remaining screw attached to the motherboard on the bottom right beneath the tape.
    • All the other screw holes (except screws holding the base cover on) are kept empty.
  17. Acer Aspire 5100 USB Add-on Card Replacement: étape 17, image 1 de 1
    • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
  18. Acer Aspire 5100 USB Add-on Card Replacement: étape 18, image 1 de 1
    • Push out the back of the casing by the VGA connector to remove the motherboard.
  19. Acer Aspire 5100 USB Add-on Card Replacement: étape 19, image 1 de 2 Acer Aspire 5100 USB Add-on Card Replacement: étape 19, image 2 de 2
    • Lift up and remove the motherboard from the laptop casing.
    • Remove the USB add-on card to use it with the new motherboard.
    • To remove, grab on the sides and lift upward.
  20. Acer Aspire 5100 USB Add-on Card Replacement, USB Add-on Card: étape 20, image 1 de 1
    • Put in new USB add-on card.
2 autres ont terminé cette réparation.
michael
Membre depuis le 09/30/10
403 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
Un commentaire
اello
I have a problem at all entrances usb not working
When Enter the device show me unknown device
  The show I've been arrested for this device that caused the problem (code 43)
I did not understand the problem, despite all attempts
Where do I start testing now, sir
I hope to answer in the near future sir
Thank you
rabah arif - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 23
Total : 9,746
