Aller au contenu principal
Acer Aspire 5253 Back Cover Panel Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5253 Back Cover Panel Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over.
  2. Acer Aspire 5253 Back Cover Panel Replacement: étape 2, image 1 de 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Back Cover Panel Replacement: étape 3, image 1 de 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Back Cover Panel Replacement: étape 4, image 1 de 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Back Cover Panel Replacement: étape 5, image 1 de 1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Back Cover Panel Replacement, Back Cover Panel: étape 6, image 1 de 1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Back Cover Panel Replacement: étape 7, image 1 de 1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Back Cover Panel Replacement: étape 8, image 1 de 2 Acer Aspire 5253 Back Cover Panel Replacement: étape 8, image 2 de 2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Back Cover Panel Replacement: étape 9, image 1 de 1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
4 autres ont terminé cette réparation.
Nathan Hanson
Membre depuis le 04/08/14
570 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-11, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 17
Total : 2,640
