Aller au contenu principal
Acer Aspire 5349-2592 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5349-2592 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Hard Drive Replacement: étape 2, image 1 de 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Hard Drive Replacement: étape 3, image 1 de 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Hard Drive Replacement: étape 4, image 1 de 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Hard Drive Replacement, Back plate: étape 5, image 1 de 1
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Hard Drive Replacement: étape 6, image 1 de 1
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Remove the the pin strip.
  8. Acer Aspire 5349-2592 Hard Drive Replacement: étape 8, image 1 de 1
    • Remove the two screws from the caddy using the Phillips #0 screwdriver.
  9. Acer Aspire 5349-2592 Hard Drive Replacement: étape 9, image 1 de 1
    • Slide out the caddy.
  10. Acer Aspire 5349-2592 Hard Drive Replacement: étape 10, image 1 de 3 Acer Aspire 5349-2592 Hard Drive Replacement: étape 10, image 2 de 3 Acer Aspire 5349-2592 Hard Drive Replacement: étape 10, image 3 de 3
    • Slightly lift up the hard drive and pull it out from the device.
3 autres ont terminé cette réparation.
Abderahmane Naidjate
Membre depuis le 04/03/19
547 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 17
Total : 1,761
