Aller au contenu principal
Acer Aspire 5734z-4836 Screen Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: étape 1, image 1 de 1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: étape 2, image 1 de 1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: étape 3, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 3, image 2 de 2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: étape 4, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement, Screen: étape 4, image 2 de 2
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: étape 5, image 1 de 1
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: étape 6, image 1 de 1
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: étape 7, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 7, image 2 de 2
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: étape 8, image 1 de 1
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: étape 9, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 9, image 2 de 2
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: étape 10, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 10, image 2 de 2
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: étape 11, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 11, image 2 de 2
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: étape 12, image 1 de 3 Acer Aspire 5734z-4836 Screen Replacement: étape 12, image 2 de 3 Acer Aspire 5734z-4836 Screen Replacement: étape 12, image 3 de 3
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: étape 13, image 1 de 2 Acer Aspire 5734z-4836 Screen Replacement: étape 13, image 2 de 2
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
Susan Cao
Membre depuis le 09/12/16
121 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team 2-3, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 849
