Aller au contenu principal
Acer Aspire 5740-5780 Back Cover Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 4 sont issues d'un tutoriel marqué comme en cours.
    Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: étape 1, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: étape 1, image 2 de 2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Back Cover Replacement: étape 2, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: étape 2, image 2 de 2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Back Cover Replacement: étape 3, image 1 de 1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Back Cover Replacement: étape 4, image 1 de 1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Back Cover Replacement, Battery: étape 5, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Battery: étape 5, image 2 de 2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Back Cover Replacement: étape 6, image 1 de 1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Back Cover Replacement: étape 7, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: étape 7, image 2 de 2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: étape 8, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: étape 8, image 2 de 2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Back Cover Replacement: étape 9, image 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: étape 9, image 2 de 2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
Dwyer Deighan
Membre depuis le 03/25/18
358 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 724
