Aller au contenu principal
Acer Aspire 5742 LCD Panel Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5742 LCD Panel Replacement, Battery: étape 1, image 1 de 3 Acer Aspire 5742 LCD Panel Replacement, Battery: étape 1, image 2 de 3 Acer Aspire 5742 LCD Panel Replacement, Battery: étape 1, image 3 de 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 LCD Panel Replacement, Screen bezel screws: étape 2, image 1 de 1
    • Open the laptop lid as far as it will go. Using a small craft knife or similar, remove the two black adhesive screw covers on either side of the screen at the bottom, by inserting the tip of the blade under the edge of the cover.
    • Remove the 2 screws now revealed.
  3. Acer Aspire 5742 LCD Panel Replacement, Removing the screen bezel: étape 3, image 1 de 1
    • Separate the bezel around the screen by using a jimmy or similar tool to release the clips holding it in place. Work around both sides and the top. Finally, turn the laptop on its side in order to work along the bottom. You should now be able to lift off the bezel.
  4. Acer Aspire 5742 LCD Panel Replacement, Removing the LCD panel: étape 4, image 1 de 1
    • Remove 2 screws from the bottom of the LCD panel.
    • At the top of the LCD panel, remove the 2 screws furthest from the corners. Support the panel as you remove these screws.
    • Very gently angle the LCD panel forwards and lay it face down.
  5. Acer Aspire 5742 LCD Panel Replacement, Disconnecting the video cable: étape 5, image 1 de 1
    • Gently lift the transparent adhesive film covering the video connector on the back of the LCD panel, and disconnect the connector.
    • You can now completely remove the LCD panel.
Philip Le Riche
Membre depuis le 02/18/14
30 111 Réputation
47 tutoriels rédigés
Équipe
Restart Project Membre de l'équipe Restart Project
Local Repair Groups
19 membres
534 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 1,396
