Aller au contenu principal
Acer Aspire 5742G Memory stick Replacement
Ce dont vous avez besoin
Vidéo d'introduction
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: étape 1, image 1 de 1
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: étape 2, image 1 de 1
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: étape 3, image 1 de 2 Acer Aspire 5742G Memory stick Replacement: étape 3, image 2 de 2
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: étape 4, image 1 de 1
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: étape 5, image 1 de 1
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
2 autres ont terminé cette réparation.
Petter Berget
Membre depuis le 05/12/15
740 Réputation
3 tutoriels rédigés
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
162 membres
300 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 784
