Aller au contenu principal
Acer Aspire 6530-6522 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire 6530-6522 RAM Replacement, Battery: étape 1, image 1 de 2 Acer Aspire 6530-6522 RAM Replacement, Battery: étape 1, image 2 de 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 RAM Replacement: étape 2, image 1 de 2 Acer Aspire 6530-6522 RAM Replacement: étape 2, image 2 de 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 RAM Replacement: étape 3, image 1 de 3 Acer Aspire 6530-6522 RAM Replacement: étape 3, image 2 de 3 Acer Aspire 6530-6522 RAM Replacement: étape 3, image 3 de 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 RAM Replacement: étape 4, image 1 de 3 Acer Aspire 6530-6522 RAM Replacement: étape 4, image 2 de 3 Acer Aspire 6530-6522 RAM Replacement: étape 4, image 3 de 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 RAM Replacement, RAM: étape 5, image 1 de 2 Acer Aspire 6530-6522 RAM Replacement, RAM: étape 5, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the nine 7mm screws holding the back panel.
  6. Acer Aspire 6530-6522 RAM Replacement: étape 6, image 1 de 1
    • Pull the release latches outward. The memory module should lift up.
    • Pull the memory up and out at about a 45 degree angle.
    • Repeat for the second module (if necessary).
Patrick McKenna
Membre depuis le 03/20/18
656 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G6, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G6, Peak Spring 2018
UMASSD-PEAK-S18S5G6
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 284
