Aller au contenu principal
Acer Aspire A515-51G Lower Case Replacement
Ce dont vous avez besoin
  1. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: étape 1, image 1 de 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
  2. Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: étape 2, image 1 de 3 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: étape 2, image 2 de 3 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: étape 2, image 3 de 3
    • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
    • Remove the HDD hatch.
  3. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: étape 3, image 1 de 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: étape 3, image 2 de 2
    • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
    • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
  4. Acer Aspire A515-51G Lower Case Replacement: étape 4, image 1 de 3 Acer Aspire A515-51G Lower Case Replacement: étape 4, image 2 de 3 Acer Aspire A515-51G Lower Case Replacement: étape 4, image 3 de 3
    • Firmly grip the HDD assembly and HDD cable connector head.
    • Pull the HDD cable connector out of its socket.
    • Remove the HDD assembly.
  5. Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: étape 5, image 1 de 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: étape 5, image 2 de 2
    • Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
  6. Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: étape 6, image 1 de 2 Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: étape 6, image 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  7. Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: étape 7, image 1 de 3 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: étape 7, image 2 de 3 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: étape 7, image 3 de 3
    • Slide the pick along the front edge to release the clips securing the lower case.
  8. Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: étape 8, image 1 de 2 Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: étape 8, image 2 de 2
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  9. Acer Aspire A515-51G Lower Case Replacement: étape 9, image 1 de 3 Acer Aspire A515-51G Lower Case Replacement: étape 9, image 2 de 3 Acer Aspire A515-51G Lower Case Replacement: étape 9, image 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Acer Aspire answers community for help.
Spencer Day
Membre depuis le 09/14/22
55 203 Réputation
408 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 12
30 derniers jours : 58
Total : 1,196
