Aller au contenu principal
Acer Aspire A515-51G SSD Replacement
Ce dont vous avez besoin
  1. Acer Aspire A515-51G SSD Replacement, Unfasten the HDD hatch: étape 1, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Unfasten the HDD hatch: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
  2. Acer Aspire A515-51G SSD Replacement, Remove the HDD hatch: étape 2, image 1 de 3 Acer Aspire A515-51G SSD Replacement, Remove the HDD hatch: étape 2, image 2 de 3 Acer Aspire A515-51G SSD Replacement, Remove the HDD hatch: étape 2, image 3 de 3
    • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
    • Remove the HDD hatch.
  3. Acer Aspire A515-51G SSD Replacement, Unfasten the HDD assembly: étape 3, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Unfasten the HDD assembly: étape 3, image 2 de 2
    • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
    • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
  4. Acer Aspire A515-51G SSD Replacement: étape 4, image 1 de 3 Acer Aspire A515-51G SSD Replacement: étape 4, image 2 de 3 Acer Aspire A515-51G SSD Replacement: étape 4, image 3 de 3
    • Firmly grip the HDD assembly and HDD cable connector head.
    • Pull the HDD cable connector out of its socket.
    • Remove the HDD assembly.
  5. Acer Aspire A515-51G SSD Replacement, Unfasten the lower case: étape 5, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Unfasten the lower case: étape 5, image 2 de 2
    • Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
  6. Acer Aspire A515-51G SSD Replacement, Insert an opening pick: étape 6, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Insert an opening pick: étape 6, image 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  7. Acer Aspire A515-51G SSD Replacement, Release the case's front clips: étape 7, image 1 de 3 Acer Aspire A515-51G SSD Replacement, Release the case's front clips: étape 7, image 2 de 3 Acer Aspire A515-51G SSD Replacement, Release the case's front clips: étape 7, image 3 de 3
    • Slide the pick along the front edge to release the clips securing the lower case.
  8. Acer Aspire A515-51G SSD Replacement, Release the remaining clips: étape 8, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Release the remaining clips: étape 8, image 2 de 2
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  9. Acer Aspire A515-51G SSD Replacement: étape 9, image 1 de 3 Acer Aspire A515-51G SSD Replacement: étape 9, image 2 de 3 Acer Aspire A515-51G SSD Replacement: étape 9, image 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Acer Aspire A515-51G SSD Replacement, Disconnect the battery: étape 10, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Disconnect the battery: étape 10, image 2 de 2
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  11. Acer Aspire A515-51G SSD Replacement, Unfasten the SSD: étape 11, image 1 de 2 Acer Aspire A515-51G SSD Replacement, Unfasten the SSD: étape 11, image 2 de 2
    • Use a Phillips screwdriver to remove the 2.8 mm screw securing the SSD.
  12. Acer Aspire A515-51G SSD Replacement, Remove the SSD: étape 12, image 1 de 3 Acer Aspire A515-51G SSD Replacement, Remove the SSD: étape 12, image 2 de 3 Acer Aspire A515-51G SSD Replacement, Remove the SSD: étape 12, image 3 de 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Acer Aspire answers community for help.
2 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
55 203 Réputation
408 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
2 commentaires
WARNING, WARNING WILL ROBINSON!!
Before you remove the lower case, you MUST remove the HDD as it is attached to the lower case. If you pull the lower case up with HDD still attached you will rip the HDD cable off the motherboard. So ...
Unscrew the HDD hatch.
Pull HDD hatch on lower right off carefully.
Unscrew the four black screws holding the HDD assembly to lower case.
Carefully pull the HDD cable off the HDD (careful here, you could rip cable off motherboard).
Carefully pry HDD assembly upwards (with spunger) and remove HDD.
Now proceed with rest of remining steps.
Would someone be able to attach photos to these steps. I don't have the ability to do so, easily.
Stephen Davidson - Réponse
I used exactly these instructions today to replace the M.2 SSD. Everything worked perfectly. Many thanks for the instructions.
Regarding
@davoesq note - in step 4 of the instructions it is described that the second hard disk, which you can reach directly, must be removed. Care must of course be taken when removing the connector.
zilpzalp - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 40
30 derniers jours : 137
Total : 2,209
