Aller au contenu principal
Acer Aspire E1-470P-6659 LCD Panel & Faceplate Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, Battery: étape 1, image 1 de 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 2, image 1 de 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 3, image 1 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 3, image 2 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 3, image 3 de 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 4, image 1 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 4, image 2 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 4, image 3 de 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, LCD Panel & Faceplate: étape 5, image 1 de 1
    • Locate the screws connected to the hinge of the laptop. Small, black stickers hide them from immediate view.
  6. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 6, image 1 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 6, image 2 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • On both corners, use tweezers to remove small plastic sticker hiding the screws.
    • Remove screws using Phillips #0 screwdriver.
  7. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 7, image 1 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 7, image 2 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 7, image 3 de 3
    • Turn the laptop over and open it up.
    • Using a prying tool, run along all edges of the display to pry the front face plate from the cover.
    • Use your fingers to pull the LCD panel and faceplate from the backing.
  8. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 8, image 1 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 8, image 2 de 3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 8, image 3 de 3
    • LCD with faceplate should separate, be careful not to pull completely away because there is a cable still attached to the display.
    • Carefully peel tape away from cable lead and separate cable from LCD panel.
  9. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: étape 9, image 1 de 1
    • Remove the LCD Panel and faceplate from the device.
Joel Humes
Membre depuis le 10/22/18
163 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S4-G5, Lore Fall 2018 Membre de l'équipe UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 membres
5 tutoriels rédigés
Un commentaire
Need more guide how to safe instal lcd, cause peel tape and need new one.. Overall good and detail love it
Kusuma Wijaya - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 25
Total : 540
