Aller au contenu principal
Acer Aspire E1-510-2500 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-510-2500 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 Motherboard Replacement: étape 2, image 1 de 2 Acer Aspire E1-510-2500 Motherboard Replacement: étape 2, image 2 de 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 Motherboard Replacement: étape 3, image 1 de 2 Acer Aspire E1-510-2500 Motherboard Replacement: étape 3, image 2 de 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 Motherboard Replacement, Motherboard: étape 4, image 1 de 3 Acer Aspire E1-510-2500 Motherboard Replacement, Motherboard: étape 4, image 2 de 3 Acer Aspire E1-510-2500 Motherboard Replacement, Motherboard: étape 4, image 3 de 3
    • Using a Phillips 1 screwdriver, remove the 17 9 mm screws from the bottom of the laptop, including the one in the back panel.
    • Using a plastic opening tool, carefully remove the back panel.
    • Remove the 9mm screw under the back panel.
    • When reassembling, insert the back panel from the bottom edge first.
  5. Acer Aspire E1-510-2500 Motherboard Replacement: étape 5, image 1 de 1
    • Using a plastic opening tool, carefully separate the frame along the edges of the laptop. This should separate the keyboard assembly from the bottom portion of the laptop.
  6. Acer Aspire E1-510-2500 Motherboard Replacement: étape 6, image 1 de 3 Acer Aspire E1-510-2500 Motherboard Replacement: étape 6, image 2 de 3 Acer Aspire E1-510-2500 Motherboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Open the laptop, leaving the screen flat on the table.
    • Carefully pull the keyboard assembly out away from the base of the laptop. There should be three connections visible in the gap between the keyboard assembly and the base.
    • Using tweezers, carefully detach the connections from the base.
    • Place the keyboard assembly and the disk tray place holder aside.
    • For reassembly, leave the disk tray place holder out until after the blue tape connector has been reconnected, to have enough space to reattach the tape. The disk tray place holder can then be slid back into place from the side of the laptop.
  7. Acer Aspire E1-510-2500 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the six wire connections to the motherboard.
    • Remove the tape connection by lifting the plastic black holding piece and carefully pulling the tape out of it's slot.
  8. Acer Aspire E1-510-2500 Motherboard Replacement: étape 8, image 1 de 2 Acer Aspire E1-510-2500 Motherboard Replacement: étape 8, image 2 de 2
    • Using a Phillips 1 screwdriver, remove the two 5mm screws from the motherboard.
    • Using a Phillips 1 screwdriver, remove the black 5mm screw from the fan.
    • Using a Phillips 1 screwdriver, remove the black 3mm screw from the WiFi card.
  9. Acer Aspire E1-510-2500 Motherboard Replacement: étape 9, image 1 de 1
    • Carefully remove the motherboard by lifting along the right edge first.
    • The headphone jack and the connection to the battery are both attached to the motherboard and under part of the casing. Pulling roughly at the motherboard could damage either or both of these pieces.
2 autres ont terminé cette réparation.
Sebastian Taylor
Membre depuis le 10/19/17
733 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 membres
6 tutoriels rédigés
Un commentaire
The wude blue touchpad ribbon is difficult to use, what is the correct way to remove/replace it?
Redally Wood - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 29
Total : 2,165
