Aller au contenu principal
Acer Aspire E1-510-2500 RAM Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: étape 1, image 1 de 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: étape 2, image 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: étape 2, image 2 de 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: étape 3, image 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: étape 3, image 2 de 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: étape 4, image 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: étape 4, image 2 de 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: étape 5, image 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: étape 6, image 1 de 3 Acer Aspire E1-510-2500 RAM Card Replacement: étape 6, image 2 de 3 Acer Aspire E1-510-2500 RAM Card Replacement: étape 6, image 3 de 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: étape 7, image 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: étape 7, image 2 de 2
    • Carefully remove the RAM card from its home.
Sebastian Taylor
Membre depuis le 10/19/17
733 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 20
Total : 572
