Aller au contenu principal
Acer Aspire E1-510P-4637 CMOS Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Battery: étape 1, image 1 de 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 2, image 1 de 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 5, image 1 de 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 6, image 1 de 2 Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 6, image 2 de 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 7, image 1 de 3 Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 7, image 2 de 3 Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 7, image 3 de 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 CMOS Battery Replacement, CMOS Battery: étape 8, image 1 de 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 9, image 1 de 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 10, image 1 de 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 11, image 1 de 1
    • Slowly rotate the back cover up to reveal cables attached to the motherboard.
    • Carefully slide the connectors out of their receptacle to remove the back panel.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 12, image 1 de 2 Acer Aspire E1-510P-4637 CMOS Battery Replacement: étape 12, image 2 de 2
    • Open the up the laptop to reveal the CMOS battery.
    • Desolder the CMOS battery to remove it. For soldering help, check out iFixit's soldering guide.
6 autres ont terminé cette réparation.
Caleb lindsay
Membre depuis le 04/11/16
778 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 34-15, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 membres
6 tutoriels rédigés
2 commentaires
molto utile e ben fatta, anche se il mio problema è più legato alla alimentazione che pare non funzionare anche senza batteria
Franco Ferrandi - Réponse
It'd be really handy if you were to list the model number of the CMOS battery so we can order one in advance.
Dave Compton (SirCompo) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 57
Total : 17,321
