Aller au contenu principal
Acer Aspire E1-510P-4637 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 2, image 1 de 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 5, image 1 de 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 6, image 1 de 2 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 6, image 2 de 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 7, image 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 7, image 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 7, image 3 de 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: étape 8, image 1 de 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 9, image 1 de 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 10, image 1 de 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 11, image 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 11, image 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 11, image 3 de 3
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 12, image 1 de 1
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 13, image 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 13, image 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 13, image 3 de 3
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 14, image 1 de 2 Acer Aspire E1-510P-4637 Keyboard Replacement: étape 14, image 2 de 2
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: étape 15, image 1 de 1
    • Remove the keyboard.
2 autres ont terminé cette réparation.
Caleb lindsay
Membre depuis le 04/11/16
778 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 34-15, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 1,180
