Aller au contenu principal
Acer Aspire E1-510P-4637 Touch Screen Display Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Battery: étape 1, image 1 de 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 2, image 1 de 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: étape 3, image 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: étape 3, image 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: étape 3, image 3 de 3
    • Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
    • Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  4. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 4, image 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 4, image 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 4, image 3 de 3
    • Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
    • Use a plastic opening tool to separate the the touchscreen from the back cover.
    • Carefully work your way around the frame and gently pry. Be careful not to brake the frame or damage the screen.
  5. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 5, image 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 5, image 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 5, image 3 de 3
    • Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
  6. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 6, image 1 de 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 6, image 2 de 2
    • Take off the yellow tape connecting the display to the border.
  7. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 7, image 1 de 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 7, image 2 de 2
    • Pull back the adhesive using the metal spudger.
    • Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
  8. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 8, image 1 de 1
    • Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: étape 9, image 1 de 1
    • Release the display from the border using your hands.
2 autres ont terminé cette réparation.
Caleb lindsay
Membre depuis le 04/11/16
778 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 34-15, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 membres
6 tutoriels rédigés
Un commentaire
the touchscreen its glue together with the LCD?
Chris Foliaki - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 1,198
