Aller au contenu principal
Acer Aspire E1-531-2438 Wifi Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: étape 1, image 2 de 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: étape 2, image 1 de 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: étape 3, image 1 de 2 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: étape 4, image 1 de 3 Acer Aspire E1-531-2438 Wifi Card Replacement: étape 4, image 2 de 3 Acer Aspire E1-531-2438 Wifi Card Replacement: étape 4, image 3 de 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: étape 5, image 1 de 1
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: étape 6, image 1 de 2 Acer Aspire E1-531-2438 Wifi Card Replacement: étape 6, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
Jakob Rinkus
Membre depuis le 03/21/19
965 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 6
30 derniers jours : 15
Total : 932
