Aller au contenu principal
Acer Aspire E1-572-6829 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-572-6829 Battery Replacement, Battery: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Battery Replacement: étape 2, image 1 de 3 Acer Aspire E1-572-6829 Battery Replacement: étape 2, image 2 de 3 Acer Aspire E1-572-6829 Battery Replacement: étape 2, image 3 de 3
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
Lauren Donlan
Membre depuis le 03/13/23
112 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-2, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 2-2, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 190
