Aller au contenu principal
Acer Aspire E1-572-6829 Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-572-6829 Fan Replacement, Battery: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Fan Replacement: étape 2, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 2, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 2, image 3 de 3
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
  3. Acer Aspire E1-572-6829 Fan Replacement, Keyboard and Touchpad Assembly: étape 3, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement, Keyboard and Touchpad Assembly: étape 3, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement, Keyboard and Touchpad Assembly: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
    • Use a plastic spudger to pry open the lower back panel from its top edge.
    • Lift the panel up and out to remove it.
  4. Acer Aspire E1-572-6829 Fan Replacement: étape 4, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 4, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 4, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 8 mm screws on the inner side of the lower back panel.
    • Use the pull tab on the left side of the 2.5 inch hard disk tray to slide it out of the SATA port.
    • The hard disk along with the 2.5 inch tray can now be safely removed.
  5. Acer Aspire E1-572-6829 Fan Replacement: étape 5, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 5, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 5, image 3 de 3
    • Flip the laptop over and open the lid so that the keyboard side is facing upwards.
    • Use a plastic pry tool to pry open the tabs holding the top panel on around all sides of the laptop.
    • Once all the tabs are free, carefully lift up the top panel to open it slightly.
    • Do not lift the top panel up too much or with excessive force since there are delicate ribbon cables on the inside that need to be disconnected before the assembly can be detached.
  6. Acer Aspire E1-572-6829 Fan Replacement: étape 6, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 6, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 6, image 3 de 3
    • Carefully detach the 3 ribbon cables connecting the top panel to the motherboard.
    • Be careful when removing the ribbon cables. Some of the connectors might have small plastic tabs that need to be lifted up before the cable can be detached.
    • The 3 ribbon cables from left to right correspond to the power button, the touch-pad, and the keyboard respectively.
  7. Acer Aspire E1-572-6829 Fan Replacement: étape 7, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 7, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement: étape 7, image 3 de 3
    • Once the ribbon cables are detached, the entire top panel consisting of the keyboard and the touch-pad assembly can safely be removed from the laptop.
  8. Acer Aspire E1-572-6829 Fan Replacement, Fan: étape 8, image 1 de 3 Acer Aspire E1-572-6829 Fan Replacement, Fan: étape 8, image 2 de 3 Acer Aspire E1-572-6829 Fan Replacement, Fan: étape 8, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws on the fan.
    • Unplug the cable connecting the fan to the motherboard.
    • Lift the fan up and out of the laptop.
Anamika Menon
Membre depuis le 03/13/23
493 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 2-2, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 102
