Aller au contenu principal
Acer Aspire E3-111-C0WA Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 2, image 1 de 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 2, image 2 de 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 2, image 3 de 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 3, image 1 de 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 4, image 1 de 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 4, image 2 de 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 4, image 3 de 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 5, image 1 de 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 5, image 2 de 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 6, image 1 de 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: étape 6, image 2 de 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: étape 7, image 1 de 2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: étape 7, image 2 de 2
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
Jonathan Chandler
Membre depuis le 10/17/17
503 Réputation
4 tutoriels rédigés
Équipe
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S1-G2, Weedon Fall 2017
UCSB-WEEDON-F17S1G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 13
Total : 598
