Aller au contenu principal
Acer Aspire E5-511p-C6US RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: étape 1, image 1 de 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: étape 1, image 2 de 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: étape 1, image 3 de 3
    • On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
  2. Acer Aspire E5-511p-C6US RAM Replacement: étape 2, image 1 de 1
    • Pull battery to remove.
  3. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: étape 3, image 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: étape 3, image 2 de 2
    • Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
  4. Acer Aspire E5-511p-C6US RAM Replacement: étape 4, image 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: étape 4, image 2 de 2
    • Pull the Optical Drive out
  5. Acer Aspire E5-511p-C6US RAM Replacement, Keyboard: étape 5, image 1 de 1
    • Remove the 17 Phillips #1 screws remaining on the back side of the laptop
  6. Acer Aspire E5-511p-C6US RAM Replacement: étape 6, image 1 de 3 Acer Aspire E5-511p-C6US RAM Replacement: étape 6, image 2 de 3 Acer Aspire E5-511p-C6US RAM Replacement: étape 6, image 3 de 3
    • Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
  7. Acer Aspire E5-511p-C6US RAM Replacement: étape 7, image 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: étape 7, image 2 de 2
    • Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
  8. Acer Aspire E5-511p-C6US RAM Replacement, Fan: étape 8, image 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement, Fan: étape 8, image 2 de 2
    • Disconnect the cord from the fan
  9. Acer Aspire E5-511p-C6US RAM Replacement: étape 9, image 1 de 1
    • Remove the 2 #1 Phillips screws
  10. Acer Aspire E5-511p-C6US RAM Replacement: étape 10, image 1 de 1
    • now the fan can be pulled from the laptop
  11. Acer Aspire E5-511p-C6US RAM Replacement, RAM: étape 11, image 1 de 1
    • Disconnect the 2 plugs remaining on the computer
  12. Acer Aspire E5-511p-C6US RAM Replacement: étape 12, image 1 de 1
    • Remove the last 2 #1 Philips screws from the body
  13. Acer Aspire E5-511p-C6US RAM Replacement: étape 13, image 1 de 1
    • Remove the 2 #1 Phillips screws, then slide the metal cover back and away
  14. Acer Aspire E5-511p-C6US RAM Replacement: étape 14, image 1 de 1
    • Remove the board from the laptop body, flip over for access to the ram
  15. Acer Aspire E5-511p-C6US RAM Replacement: étape 15, image 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: étape 15, image 2 de 2
    • Press down on the spring clips on either side of the ram, It will unlock and can be removed
Aaron
Membre depuis le 03/19/18
562 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S2G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 15
Total : 664
