Aller au contenu principal
Acer Aspire E5-571-58CG CPU Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: étape 2, image 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 2, image 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 2, image 3 de 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: étape 3, image 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: étape 3, image 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: étape 3, image 3 de 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: étape 4, image 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 4, image 2 de 2
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: étape 5, image 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 5, image 2 de 2
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: étape 6, image 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: étape 7, image 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 7, image 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: étape 7, image 3 de 3
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Brendan Cuthill
Membre depuis le 10/29/18
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 12
Total : 305
