Aller au contenu principal
Acer Aspire E5-571-58CG Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571-58CG Keyboard Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E5-571-58CG Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Keyboard Replacement: étape 2, image 1 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 2, image 2 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 2, image 3 de 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Keyboard Replacement: étape 4, image 1 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 4, image 2 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 4, image 3 de 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  5. Acer Aspire E5-571-58CG Keyboard Replacement: étape 5, image 1 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 5, image 2 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 5, image 3 de 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  6. Acer Aspire E5-571-58CG Keyboard Replacement: étape 6, image 1 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 6, image 2 de 3 Acer Aspire E5-571-58CG Keyboard Replacement: étape 6, image 3 de 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
Matthew Barboza
Membre depuis le 10/19/18
159 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 466
