Aller au contenu principal
Acer Aspire E5-571-58CG Touchpad Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: étape 1, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: étape 1, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: étape 1, image 3 de 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  2. Acer Aspire E5-571-58CG Touchpad Replacement: étape 2, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 2, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 2, image 3 de 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  3. Acer Aspire E5-571-58CG Touchpad Replacement: étape 3, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 3, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 3, image 3 de 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  4. Acer Aspire E5-571-58CG Touchpad Replacement: étape 4, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 4, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 4, image 3 de 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
  5. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: étape 5, image 1 de 2 Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: étape 5, image 2 de 2
    • Make sure you have removed the keyboard before attempting to remove the touchpad.
    • Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
  6. Acer Aspire E5-571-58CG Touchpad Replacement: étape 6, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 6, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 6, image 3 de 3
    • Peel back the marked strips with the metal spudger.
  7. Acer Aspire E5-571-58CG Touchpad Replacement: étape 7, image 1 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 7, image 2 de 3 Acer Aspire E5-571-58CG Touchpad Replacement: étape 7, image 3 de 3
    • Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
  8. Acer Aspire E5-571-58CG Touchpad Replacement: étape 8, image 1 de 2 Acer Aspire E5-571-58CG Touchpad Replacement: étape 8, image 2 de 2
    • Lift the touch pad out of the metal panel with a metal spudger.
Daniel Mello
Membre depuis le 10/16/18
258 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 1,239
