Introduction
If your Acer Aspire E5-571P-55TL isn't responding to keyboard input, or if keys are missing, you may need to replace the keyboard. The keyboard's physical switches are susceptible to damage over time. Things like dust, sticky liquids, and other debris may prevent these switches from functioning. To see common issues which may require keyboard replacement, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the keyboard for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
Ce dont vous avez besoin
Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
Carefully place your fingers underneath the top of the keyboard just below the screen.
Pull upwards until you can hear the keyboard click out of place.
Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
