Aller au contenu principal
Acer Aspire E5-573G Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-573G Fan  Replacement, Fan: étape 1, image 1 de 2 Acer Aspire E5-573G Fan  Replacement, Fan: étape 1, image 2 de 2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
  2. Acer Aspire E5-573G Fan  Replacement: étape 2, image 1 de 2 Acer Aspire E5-573G Fan  Replacement: étape 2, image 2 de 2
    • Remove the CD drive located on the side of the laptop.
  3. Acer Aspire E5-573G Fan  Replacement: étape 3, image 1 de 1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
  4. Acer Aspire E5-573G Fan  Replacement: étape 4, image 1 de 3 Acer Aspire E5-573G Fan  Replacement: étape 4, image 2 de 3 Acer Aspire E5-573G Fan  Replacement: étape 4, image 3 de 3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
  5. Acer Aspire E5-573G Fan  Replacement: étape 5, image 1 de 2 Acer Aspire E5-573G Fan  Replacement: étape 5, image 2 de 2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
  6. Acer Aspire E5-573G Fan  Replacement: étape 6, image 1 de 3 Acer Aspire E5-573G Fan  Replacement: étape 6, image 2 de 3 Acer Aspire E5-573G Fan  Replacement: étape 6, image 3 de 3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
Lara Mustafa
Membre depuis le 01/08/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G20, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G20, O'Regan Winter 2021
YORK-O'REGAN-W21S1G20
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 29
Total : 830
