Aller au contenu principal
Acer Aspire E5-575G-39HV Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: étape 1, image 1 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: étape 1, image 2 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: étape 1, image 3 de 3
    • Unscrew all 16 screws holding the back panel.
    • Open the HDD, SSD and RAM cover and unscrew all visible screws that hold the panel. Now is a good idea to upgrade those parts if you want.
    • Use a prying tool to separate the top and bottom pieces.
  2. Acer Aspire E5-575G-39HV Keyboard Replacement, The insides.: étape 2, image 1 de 2 Acer Aspire E5-575G-39HV Keyboard Replacement, The insides.: étape 2, image 2 de 2
    • Disconnect all visible connectors, starting with the battery (Yellow), they the other ones (Blue). After that remove the screws attaching the motherboard to the panel.
    • After that remove the black protective film, without damaging it. Now the keyboard should be revealed.
  3. Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: étape 3, image 1 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: étape 3, image 2 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: étape 3, image 3 de 3
    • Remove the screws that hold the display hinges and detach the display.
  4. Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: étape 4, image 1 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: étape 4, image 2 de 3 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: étape 4, image 3 de 3
    • Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
    • Use a prying tool the remove the metal case.
    • Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
Simeon Brankov
Membre depuis le 11/08/20
6 094 Réputation
51 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 24
Total : 631
