Aller au contenu principal
Acer Aspire E5-721-64T8 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-721-64T8 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Hard Drive Replacement: étape 2, image 1 de 1
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Hard Drive Replacement: étape 4, image 1 de 2 Acer Aspire E5-721-64T8 Hard Drive Replacement: étape 4, image 2 de 2
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Remove the four 3mm Phillips #0 screws from the hard drive.
  6. Acer Aspire E5-721-64T8 Hard Drive Replacement: étape 6, image 1 de 1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF connector and remove the hard drive from the laptop.
Ed Herrera
Membre depuis le 01/25/18
390 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S7-G3, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 901
